files D&R Airlite Mapping/Integration Example
Michel67
Post by Michel67 »
Have problems set up D&r Airlite USB and Proppflexx, need help.
-airlite control up and running (usb connect at master)
-proppfrexx onair (laterst version) in demo mode
-GPIO client up and running
- airlite-config-preset: Load this preset at the airlite configuration manager = OK
- airlite.events: Load this events file at the general settings => Events/Commands
first export current event to backup file, then import the same file, results in an error! same with this preset file
- airlite.mixer: ProppFrexx Mixer and Routing for Airlite
Where load this mixer file?
- Default.drl: GPIO Remote Mapping for Airlite
Where load this file?
How is the Airlite configured with this sample?
Channel 1-3: Mic
Channel 4: Player A
Channel 5: Player B
Channel 6: Player C
Channel 7: Cartwall and PFL Player and Overlay Player
Channel 8: VoIP / Skype
First row of control buttons 1-8: Cartwall 1 (start / stop 1-8 entries)
Local soundcard: Monitor signal (same as PFL).
USB 1 Output (Main Out): In 1 at ProppFrexx. This channel has to selected for stream source. Hasn´t to be unmuted. (see page 19 of the airlite manual)
USB 3 Output (Voice Track signal): In 2 at ProppFrexx for voice tracking and pre recording your voice. (see page 19 of the airlite manual)
Installation:
1) Import all files at the right direction.
2) Check your mixer settings and add the correct usb channels of the airlite to your single in- and outputs.
3) Restart ProppFrexx.
I really appreciate any help you can provide
Re: files D&R Airlite Mapping/Integration Example
Which airlite preset files are yountalking about.
I assume it might be a set of config files provided by a user?!
meisterpropper
Post by meisterpropper »
I´ve created these files - what is exactly your problem? You have to place the files at C:\User\your-username\AppData\Roaming\radio42\...
dlr file need to be stored at C:\User\your-username\AppData\Roaming\radio42\ProppFrexx GPIO/4.0/
Try the new events export. I´ve updated the repository: https://github.com/benhartwich/proppfre ... ee/Airlite
Loading the mixer file: Place the file at C:\User\your-username\AppData\Roaming\radio42\ProppFrexx On Air/4.0 and you can load it within the settings sections at Input/Output
Michel67
Post by Michel67 »
thanks, I'm one step further now!
can't Load airlite.events file at the general settings => Events/Commands
29-11-2016 10:34:59 [v4.0.2.8]:********** Error/Exception Information **********
Error Message: Index was out of range. Must be non-negative and less than the size of the collection.
Parameter name: index
Error Type: System.ArgumentOutOfRangeException
Error Source: mscorlib.System.Object get_Item(Int32)
at System.Collections.ArrayList.get_Item(Int32 index)
at ProppFrexx.OptionDialog.lEH1(TreeListNode , Int32 , Profile , String , Int32& )
at ProppFrexx.OptionDialog.iEHN(Object , EventArgs )
at System.Windows.Forms.Control.OnClick(EventArgs e)
at DevExpress.XtraEditors.BaseButton.OnMouseUp(MouseEventArgs e)
at DevExpress.XtraEditors.BaseControl.WndProc(Message& msg)
********** End **********
the faders starts en stops now but can't change the volume?
I still have a lot to find out
that's indeed an error in the Event-Importer.
A fix is now available in the v4.0.2.9-beta (so please "Check for Beta-Versions...").
Sorry for the inconvenience.
Michel67
Post by Michel67 »
thanks for the reply
I would like to change the volume with the faders, but can only start and stop the players?
The D&R Airlite does not allow this. Only an ON/OFF state is reported by the Airlite, but not any fader position!
However, this is also normally not needed, as the Airlite is a real mixer and not a console; meaning the fader position of the Airlite already changes the volume of the related channel.
If you would in addition also change the volume of a PF mixer channel in parallel; you would change the volume twice! This is normally not desired!
Michel67
Post by Michel67 »
there was a problem with USB in windows which Proppfrexx ONAIR not working properly, it has been resolved. The beta version v4.0.2.9 is unfortunately jammed a few times. v4.0.2.8 working stable
If PF 'jammed' there will be some entry in the file called 'Error.log' in the AppUserData folder.
Else it was probably your system which 'jammed'?!
