Try Ensure Exact Length and Playlists
inl_inc
Post by inl_inc »
I haven't posted a request in quite a long time - which quite frankly is a testament to how professional ProppFrexx has become. However, I just encountered a problem that I hope you may have a solution for. As a matter of fact I think that ProppFrexx may already have this - but I just need you to confirm it.
Our programming consists of randomly generated 1 hour programs and 1 hour pre-programmed playlist DJ shows. We do use the Try Exact Length option in the scheduler for the randomly generated programs - and this works consistently without fail. We use a threshold of 90sec under and 300 over. 99% of the time each program begins at the top of the hour, and an acceptable number of under/overruns which are within the threshold levels.
Now here comes the problem that I hope you will have a solution for. A 1 hour random program, prior to the DJ show, ran for 58:33 ( basically within the 90 second threshold). It was followed by a 1 hour pre-programmed DJ show - and in this particular case the playlist was only 59:20 long. After the last playlist song played - the playlist started to repeat itself until the 90 sec threshold was met (ID and the first song repeated).
If I was to add a random song entry directly after the load playlist entry in the script - would this have prevented the playlist from repeating itself? And will this last random entry be always skipped when the length threshold of the program is met?
Re: Try Ensure Exact Length and Playlists
Yes.
The typical way to 'script' a pre-programmed show (playlist) is the follwing:
1. In your first script-line schedule the related pre-programmed show, e.g. via the 'LoadPlaylist' or 'LoadTrack' mode
2. Then add a few more script-line, just as you need them. These are just there in case the pre-programmed show is 'short'
3. Make sure to set the script-option 'Loop Line' to the value 2 (this to prevent the first script-line to ever repeat)
That's it.
