GPIO_Start_Vellemanserver
atlantic
Post by atlantic »
I have a problem with gpio_start_vellemanserver. If I turn on AutoPlay stops gpio velleman, but when I turn it back off, it does not return to the gpio start velleman. I have made a movie.
https://dl.dropboxusercontent.com/u/170 ... TOplay.mp4
Re: GPIO_Start_Vellemanserver
Can you please enable the 'Debug Logging' option in the GPIO-Client application and then (after you tried it again) send me the Debug_ .log file of the ProppFrexx GPIOClient (its contained in the AppUserData folder of the ProppFrexx GPIOClient).
Yes, there seems to be an issue in your case with starting the Velleman interface again.
I can not say why (as here for example it works fine) - but the log "DispatchCommand Reply: ERROR: unknown - command cannot be executed" indicates, that the start can not be executed.
Unfortunately I currently cannot say why in your case.
So I need to provide you with a newer version which logs a few more details to 'see' what exactly is failing in your case...
I'll let you know when a newer version is available to test with ...
atlantic
Post by atlantic »
yes yes everything works as it should be. Thank you ;)
After some more investigation, I guess I have found the issue.
A new v4.0.1.66-beta (see "Check for Beta-Versions...", located under the blue question mark icon at the very top right) is available to test.
