Exclude from Title update
Frans
Post by Frans »
I exclude jingles from Title Update through the Title update filter. This works only half voor me.
The name of the jingle won't show on the stream, thats good.
But it won't show the Song Title I filled in at the form "Select entry type Song Title". Instead the stream is filled with the Initial Title (Streaming -> Edit stream -> Initial title).
Any ideas?
Greetings
Re: Exclude from Title update
Where/How do you play the Jingle?
I just made a quick test here and it worked like expected, so I guess there must be some other difference.
Note, that you must set the 'Use MediaType for excluded Tracks' - 'Streaming Option' (see general settings, section 'Streaming').
Did you do that?
Frans
Post by Frans »
Yes, I forgot that combobox 'Use MediaType for excluded Tracks'.
It works fine now.
Thank you.
I have got another streaming question.
I'm using the Overlay scheduler to play the news.
Title updates = Use Overlay Description. This works fine, however:
I'm using a script within the Overlay
1. Tune
2. News
3. Tune
In this case the stream will be updated multiple times (with the same Overlay Description). Is it possible to just update one time for the complete Overlay?
No, that is currently not possible, but why is this an issue?
However, I might take a look, if I can do this automatically in a next release with the 'OverlayName', 'OverlayReference', 'OverlayDescription' and 'InitialTitle' option.
Frans
Post by Frans »
It's not a huge issue, but on a website with the song history showed, the news is displayed multiple times.
So
Song 1
News
News
News
Song 2
The red titles come from the overlay scheduler
Thanks in advance
Except you implement a check on the web site to suppress sub-sequent duplicate song-titles ;-)
But as said: ... I might take a look, if I can do this automatically in a next release with the 'OverlayName', 'OverlayReference', 'OverlayDescription' and 'InitialTitle' option.
