Main
Main
Hi, Bernd,
Just to let you know that “Main”, in the “Main Mixer”, is back again! I did not use the “Wizard” and did not make any changes. This occurs after the last update; at least it was when I noticed.
As you know it is not a problem, does not affect PFOA, so we can leave as it is unless you have a different opinion.
Regards
Luis
Regards
Luis
- main.JPG (59.5 KiB) Viewed 5179 times
The older I get, the better I was.
Re: Main
I remember the last time you removed a channel and thought it was this Main (in the Main Mixer, not the "Main Mixer" itself). It must have been another. Sorry for my confusion.
Re: Main
I am not sure what you mean?!
The "Main Mixer" is a dock panel window which is always there - so it can not be deleted or removed as such of course it is there.
The "MAIN" channel strip is also always there (it is a fixed component and NOT a real mixer channel, it controls the global volume) - so it can also not be deleted or removed as such of course it is there.
Can you clarify what you exactly mean?
Re: Main
Yes, it was a real mixer channel named "MON" which I removed in our TeamViewer session
