Marked and remove played
Farbo
Post by Farbo »
Bernd, in newly installed PF settings are as shown on the picture. But Tracks are not removed from playlist when played. What else shall I set?
Marked Played.jpg (17.52 KiB) Viewed 19150 times
Peter
Re: Marked and remove played
Please check the status bar of your playlist window.
Does that also show "Remove Played"?
Note, that the above settings are the default for new playlist windows.
You can however change and overwrite this manually via the status bar buttons (at the bottom) of each playlist window.
So maybe you have changed that there.
Farbo
Post by Farbo »
Status bar says "Remove Played"
Peter
Farbo
Post by Farbo »
They are present there and of course unloaded. I do not understand it as the setting is the same as on my other computer and it is working there.
Peter
If a track is still loaded to a DJ Player, it wouldn't be marked as played, as it would only be marked as played (resp. removed when played), once the track is unloaded from the DJ Player.
So maybe your default playlist setting for 'Auto Load' resp. 'Auto Unload' are different.
Farbo
Post by Farbo »
I do not understand. I thought AutoUnload means track will be unloaded from DJ Player and that´s it. In this case it should also be removed from playlist.
Peter
Farbo
Post by Farbo »
But when Autoplay is activated also autounload and autoload are activated so remove played should work fine. Or?
Peter
That's a bit strange. I can not reproduce that here.
Are the 'played' entries ejected from the DJ Players but are marked as played (*) instead or what is exactly happening?
'AutoUnload' and 'Remove Played' are simply independent settings.
Yes correctly, and here in all my tests it works fine.
