v4.0.1.52 - stable
v4.0.1.52 - stable
Version 4.0.1.52 is out!
What's New?
  • New control-commands added
  • New 'Don't Repeat in X days' track restriction rule added
  • New 'Global Restrictions...' added (extended global script rules)
  • Initial FTE backtime adjustment calculation bug-fix
  • Other smaller bug-fixes
  • stable
The global song history settings can now be found in the general settings under 'Logging/History'.
The Track related Restrictions have been enhanced by another rule (e.g. see TAG Editor, 'Other' tab)
Don't Repeat in X days: Defines the number of days in which this track should not be repeated.
Beside script related Rules, you can now also define Global Scripting Restrictions - see in general settings, section 'Logging/History', and click on the global 'Restrictions...' button.
Global Restriction Rules allow you to not schedule more than a certain number of tracks all matching the same meta-data filter condition rule in a row.
Scope: If set to Global, the rule is evaluated after the actual script-line processing, meaning a related matching track might be suppressed after. If set to ScriptLine scope, the evaluation takes place during the processing and the related script-line will be executed again to find a non-matching track (up until a maximum number of retries).
Track Condition: The track condition is a mata-data based filter rule expression, which much match in order to suppress the track.
Applies To: Defined to which script-line modes this rule applies to. This allows you to exclude the rule from certain type of script-lines (e.g. FTE's, LoadFolder or Cartwall results etc.)
Count Back: The number of directly preceeding (historical) global song history entries which much also match the given track filter condition. E.g. 5 in order to check, that not more then 5 tracks in a ro do match this condition.
In addition you can also specify, that a certain track when once played will not be scheduled again the next time in the same hour.
See 'Do not play a track (the next time it will be scheduled) again in the same hour plus/minus:...':
The plus/minus hour value allows you to adjust the total time frame in which the track should not be repeated. E.g. a value of 0 means the exact hour. A value of 1 denotes a 3 hour frame, a value of 2 a 5 hour and a value of 3 a 7 hour time frame.
Note: This is a ScriptLine rule which only applies to Random or Sequential modes.
Dynamic Scripting
Even if already implemented for quite some time, I would just like to emphasize again, the dynamic scripting is also possible.
This means, that you can add rules (resp. a filter) to a script-line, which contains attributes from your last scheduled track (your previous executed script-line). Meaning you create a script-line filter condition which is based on the previous scheduled track.
In order to do so, you can simply use any standard track macros within script-line filters! Any regular track macro like for example ${genre} will then be replaced by the data of the last scheduled track.
E.g. the following filter would make sure, that the Genre of the current script-like is the same as the genre of the previous scheduled track; but the rating must be different:
~[Genre] == '${genre}' And [Rating] <> '${rating}'
