v3.0.11.10 - stable
v3.0.11.10 - stable
Version 3.0.11.10 is out!
What's New?
  • Scheduler Import enhanced (to support FTE and TUS)
  • ControlRoom Messages now support HTML code
  • Mixer-Input-Channel Processing mode added
  • TimeUpdateSync handling improved/bug-fix
  • Various other optimizations
  • Other smaller bug-fixes
  • stable
The scheduler import formats now fully support FixTime-Elements and TimeUpdateSyncs.
You might use standard command blocks to do so. The command notation is as followed:
“FTE Type=<type> [Start=<mm:ss>|<hh:mm:ss>] [Dur=<approxDuration>] [<text>]”
resp.
“TUS Type=<type> [Start=<mm:ss>|<hh:mm:ss>] [<trackname>]”
You can now use HTML code within your Message-Center messages.
E.g. like this:
SET_MESSAGECENTER_MESSAGE Some <big>Bigger Text</big><br/><b>Something Bold</b> <i>Italic</i> <u>Underlined</u><br/><BaseFont size=10>Size = 10</BaseFont><br/><BaseFont Color="red">something in red</BaseFont>
In the context menu of a mixer-input-channel you'll now find a 'Processing' mode sub-menu in which you can set the processing signal mode to:
Stereo: Default processing
Mono Standard: The incomming audio signal is converted to Mono (= Left+Right / 2)
Mono Left: The incomming audio signal is converted to LeftMono (= Left / 2)
Mono Right: The incomming audio signal is converted to RightMono (= Right / 2)
This setting was added only for soundcards which doesn't allow you to natively record in Mono (accepting the Mono option in the mixer-input configuration settings), but always record 2-channels (stereo) and as such when connecting e.g. a mono microphone would process the audio signal e.g. as the left channel only.
Note: v3.0.11.7 to v3.0.11.9 had been intermediate releases.
Farbo
Re: v3.0.11.9 - stable
Post by Farbo »
Updater says an update 3.0.11.6 is ready and not 3.0.11.9. Is it correct? PF downloads 3.0.11.6 update. But after update version 3.0.11.9 is installed so everything is fine, it is just "cosmetic" mistake in spelling.
Peter
Yes, that's also already fixed with v3.0.11.9 ;-)
