Recording filename
XTended
Recording filename
Post by XTended »
The settings of Automatic Mixer Channel Recording: recording filename are ${yyyy}-${MM}-${dd}-${programname}.
But after recording the filename is for example only "2016-05-20-.mp3" instead of "2016-05-20-xtendeddance.mp3".
How can I fix that?
Re: Recording filename
${programname} is a scheduler macro and as such can only be used in the scheduler related events.
However, in the recording settings you can ONLY use the global macros (see the User Manual Appendix for details).
As such use the ${progcurrentname} macro instead.
XTended
Post by XTended »
I just checked the Appendix and read it on page 286.
Thanks for your fast support Bernd and have a nice weekend!
