New mix settings
New mix settings
Hi Bern,
Could you add new mix function, like this:
If next song have In and Full point, mix takes place so that the Next point meets with the Full point of next track. Thanks. P.
- Mix.png (3.67 KiB) Viewed 24709 times
Re: New mix settings
If you send me your audio files as well as your exact mixing settings (from the above post I can not really follow
I might try to reproduce what you are saying... please also let me know what exact version you are using...
I am sorry but that makes no sense.
The NEXT cue point is defined to be the point where the next track should start.
As you define the IN and FULL resp. the FADE and OUT cue points anyhow, why don't you define the NEXT cue point accordingly to your requirements.
Because some songs begin before the raid comes first beat. And if the previous song ends cut, I want to put on themselves last and first beat seats
I guess in that case you can still set the segue manually? Or not?
Else have you tried the limit options in the mixing settings?
However there are always cases where an automatic segue might fail.
So I am still not sure why your new mix option would help, if that is set in general ?
Manually of course yes. I have set mixing point at all songs - In, sometimes in combination In-Full, Ramp, Fade, Next and Out. Needed at night or in automatic mode would be handy if it mixing as manual editing
Not sure what you means, as with the ACPD modes incl. the mentioned limit modes all is possible as far as automation can do it.
So I am still not sure what is missing.
Here is example in mp3, what I want: http://www.uschovna.cz/zasilka/JFYSPTWW9CJSKJT3-SH6
CartMaster from 8bc have other mix point called MixIn. It is a point that he meets with "Next" point in previous track. Before this point It can be done independent fade in (as PFOA with In and Full points).
I understand that Propp is different and I saying: It is better than more automation software which I used in the past!
I understand the recommended settings too. But this method I can not be use. My MP3 have manually sets all mix points. I don't use ACPD. Fade In at the beginning of the track is not a rule. If they went an extra point (like MixIn) in the future to add, I would like to
I see what you mean. I'll see what can be done.
