PF crashes
SiriusRadio
PF crashes
Post by SiriusRadio »
Bernd,
Everytime when i try to change anything in the view sector, PF gets on hold for a long time, or even crash. The processor gets occupied and uses more than 50 % of the total capacity.
I did run a bug report but i didn't change anythinh. The only thing i did was deleted a single track out of the playlist during its playing. That track was scheduled next, was loaed but not playing. Since than the realtime window is gone ( not able to sartup again) and so on.
Hereby the bug report
1-5-2016 11:46:28 [v3.0.15.21]:********** Error/Exception Information **********
Error Message: Object is currently in use elsewhere.
Error Source: System.Drawing.System.Drawing.GraphicsUnit get_PageUnit()
at System.Drawing.Graphics.get_PageUnit()
at DevExpress.Utils.AppearanceObject.CalcDefaultTextSize(Graphics g)
at DevExpress.XtraEditors.ViewInfo.BaseControlViewInfo.CalcTextSizeCore(GraphicsCache cache, String text, Int32 maxWidth)
at DevExpress.XtraEditors.ViewInfo.BaseControlViewInfo.CalcTextSizeCore(Graphics g, String text, Int32 maxWidth)
at DevExpress.XtraEditors.ViewInfo.BaseControlViewInfo.CalcTextSize(Graphics g, Boolean useDisplayText)
at DevExpress.XtraEditors.ViewInfo.ButtonEditViewInfo.CalcTextSize(Graphics g, Boolean useDisplayText)
at DevExpress.XtraEditors.ViewInfo.BaseEditViewInfo.CalcConstants()
at DevExpress.XtraEditors.ViewInfo.TextEditViewInfo.CalcViewInfo(Graphics g)
at DevExpress.XtraTreeList.ViewInfo.CellInfo.CalcViewInfo(Graphics g, Point pt, Rectangle bounds)
at DevExpress.XtraTreeList.ViewInfo.CellInfo.CalcViewInfo(Graphics g)
at DevExpress.XtraTreeList.ViewInfo.TreeListViewInfo.UpdateCell(CellInfo cell, TreeListColumn col, TreeListNode node)
at DevExpress.XtraTreeList.ViewInfo.TreeListViewInfo.CalcRowCellsInfo(RowInfo ri, ArrayList viewInfoList)
at DevExpress.XtraTreeList.ViewInfo.TreeListViewInfo.CalcRowInfo(RowInfo ri, ArrayList viewInfoList)
at DevExpress.XtraTreeList.ViewInfo.TreeListViewInfo.CalcRowGroupInfo(TreeListNodes nodes, CalcRowGroupInfoArgs rowArgs)
at DevExpress.XtraTreeList.ViewInfo.TreeListViewInfo.BriefCalcRowsInfo()
at DevExpress.XtraTreeList.ViewInfo.TreeListViewInfo.CalcRowsInfo()
at DevExpress.XtraTreeList.ViewInfo.TreeListViewInfo.CalcViewInfo()
at DevExpress.XtraTreeList.TreeList.UpdateLayout()
at DevExpress.XtraTreeList.TreeList.LayoutChanged()
at DevExpress.XtraTreeList.TreeList.EndUpdate()
at DevExpress.XtraTreeList.TreeList.OnEndSorting()
at DevExpress.XtraTreeList.TreeList.DoSort(TreeListNodes nodes, Boolean makeFocusedNodeVisible)
at DevExpress.XtraTreeList.TreeList.EndSort()
at DevExpress.XtraTreeList.TreeList.EndUnboundLoad()
at ProppFrexx.io.a(TreeListNode A_0, FileSystemInfo[] A_1)
at ProppFrexx.io.k.a()
at System.Windows.Forms.Control.InvokeMarshaledCallbackDo(ThreadMethodEntry tme)
********** End **********
Re: PF crashes
Looks like your layout might got corrupted.
Try ro delete the .layout file in your ProppFrexx AppUserData folder.
And update to the latest version.
SiriusRadio
Re: PF crashes
radio42 wrote:Looks like your layout might got corrupted.
Fixed
Will
inl_inc
Re: PF crashes
Post by inl_inc »
just wanted to mention that v4 of proppfrexx is much more stable ... thanks bernd
my proppfrexx instance has been running continuously for 59 days 11 hours and 57 minutes as of right now (restarted it 59 days ago for a version upgrade) ... in contrast v3.0 would crash every time by the 30 day mark ...
kinda worried that a crash may be just around the corner ... ;) ... but will let it run for now ... 59 days of cotinuous uptime streaming is certainly my personal record so far
