upgrade to windows 10
This forum is unmoderated!
jeejee99
Post by jeejee99 »
Hi there,
I want to upgrade my windows 8.1 machine to windows 10.
Does this have any negative effects I should think about?
And also does the license key still work?
I want to do an in place upgrade Im using version 4.0.1.26
Greetings,
Jeroen
Re: upgrade to windows 10
v4.0.1.26 will work fine on Windows 10.
If the license key still works, depends if your Ident-Number, which might change, if you e.g. change your computer name, domain name etc.
But if they stay the same and the hardware stays the same too, the Ident-Number should not change.
An upgrade should have no real side effects, except, that your soundcard drivers might change and thus you might need to setup your mixer again...but that depends on the soundcard driver signature.
jeejee99
Post by jeejee99 »
Thank you for your reply
I will upgrade my machine today
Thx
