Auto Load and Auto Unload default setting ignored
Havenstad FM
Post by Havenstad FM »
If I understand it correctly in the Settings and Options, category Playlist Settings, i set the default behavior for a new playlist.
As can be seen in the picture below i checked Auto Load and did not check Auto Unload.
When a playlist is generated the Auto Unload button is still activated as you can see in the next screenshot
Is the setting only applicable to manually generated playlists? or is this a small bug?
Regards,
Jack Reitsema
ICT Havenstad FM
Re: Auto Load and Auto Unload default setting ignored
Is that with a playlist generated by the scheduler?
If yes note that these settings are only valid for manual playlists. As when AutoPlay is activated these settings will and must be overwritten.
Havenstad FM
Ah, after posting the message i noticed the difference between manual and scheduled playlists.
Thanks Bernd, i am a bit wiser again.
Greetings and regards,
Jack Reitsema
ITC Havenstad FM
