Media libraries and playlists gone in media library server
Yesterday i noticed that my nonstop system wasn't working anymore.
Started the unit again and no nothing happened
After some investigation, i saw that all my media libraries and playlists in de media library server are gone.
Nothing happened here, using the latest version of proppfrexx version 4
Do i have to add them again, or can i recover those settings?
Friso
Friso
Re: Media libraries and playlists gone in media library server
They would for sure never disappear by itself !
Maybe you had a disk crash or your hard drive was not accessible anymore? Or someone deleted them manually? Hard to say, but one thing is for sure: they cannot disappear just out of the blue.
Check the file "ProppFrexx MediaLibraryServer.medialibs" in the Media Library Server's AppUserData folder. If that file is 'empty' or gone someone must have deleted the entries or the entire file manually!
If that file still exists, open it with a text editor and check the paths in that file!
I once had a user, where his hard disk assignment changed from D: to E: and thus all media lib entries became invalid, as they now pointed to a non existing drive mapping.
Bernd
And again, i updated my version to .25 and all my libraries are gone again. Watching te medialib file all is there, but nothing is displayed in the server anymore.
So no songs are available in proppfrexx.
Do you still beleve that i made a mistake?
Friso
Friso
I don't know what you do.
Do you gracefully shutdown the MLS before you do the update?
If not and you kill the MLS, I wouldn't wonder.
I can just say that I cannot reproduce hat here and that I haven't heard from other users that this is happening.
So I am wondering what I can do about it?
Bernd
I have to kill it, because when i update proppfrexx, the media library server doesn't close, and right mouse button en close also is not working.
When i look in the config file all entries are there, but not vissible in the gui of the media library server
Then there is no wonder!
And there is no need to kill it!
When you do the update BEFORE you start the update process - just right-click on the MLS user inderface and select "Close Media Library Server" - depending on your media libs (as all will be fully saved at that time) this might take a couple of seconds up to 1 or 2 minutes... so just be patience...
17-4-2016 19:16:06 [v4.0.1.25]:********** Error/Exception Information **********
Error Message: Geen toegang tot een verwijderd object.
Objectnaam: ProppFrexxMediaLibraryServer.
Error Type: System.ObjectDisposedException
Error Source: System.Windows.Forms.Void CreateHandle()
bij System.Windows.Forms.Control.CreateHandle()
bij System.Windows.Forms.Form.CreateHandle()
bij System.Windows.Forms.Control.get_Handle()
bij System.Windows.Forms.Control.SetVisibleCore(Boolean value)
bij System.Windows.Forms.Form.SetVisibleCore(Boolean value)
bij ProppFrexx.ProppFrexxMediaLibraryServer.prK()
bij ProppFrexx.ProppFrexxMediaLibraryServer.Rre(Object , EventArgs )
bij System.Windows.Forms.NotifyIcon.WmMouseDown(Message& m, MouseButtons button, Int32 clicks)
bij System.Windows.Forms.NotifyIcon.WndProc(Message& msg)
bij System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
bij System.Environment.GetStackTrace(Exception e, Boolean needFileInfo)
bij System.Environment.get_StackTrace()
bij ProppFrexx.ProppFrexxMediaLibraryServer.auW(Exception , Boolean )
bij ProppFrexx.ProppFrexxMediaLibraryServer.qu4(Exception )
bij ProppFrexx.ProppFrexxMediaLibraryServer.krz(Exception )
bij ProppFrexx.ProppFrexxMediaLibraryServer.KrU(Object , ThreadExceptionEventArgs )
bij System.Windows.Forms.Application.ThreadContext.OnThreadException(Exception t)
bij System.Windows.Forms.UnsafeNativeMethods.PeekMessage(MSG& msg, HandleRef hwnd, Int32 msgMin, Int32 msgMax, Int32 remove)
bij System.Windows.Forms.Application.ComponentManager.System.Windows.Forms.UnsafeNativeMethods.IMsoComponentManager.FPushMessageLoop(IntPtr dwComponentID, Int32 reason, Int32 pvLoopData)
bij System.Windows.Forms.Application.ThreadContext.RunMessageLoopInner(Int32 reason, ApplicationContext context)
bij System.Windows.Forms.Application.ThreadContext.RunMessageLoop(Int32 reason, ApplicationContext context)
bij We.pM.Lb9(String[] )
********** End **********
What have you now done? When does this turn up?
Maybe you need to remove your broken files, as you previously killed the MLS instead of closing it.
So may be you need to delete you MLS AppUserData folder.
And set it up again.
Bernd
I deleted all the folders in de media server folder in the app folder.
Started the server again, and it created back the 4.0 folder and the 4.0.1.25 folder.
I have added 1 media library and closed the server and started it again. Now the folder is still there.
After this i shutted down the server and addeded the ProppFrexx MediaLibraryServer.medialibs. Between the tags <MediaLibraries> and </MediaLibraries> i addedd this libraries:
<MediaLibraries>
<add key="\\DS713\music\CD" value="0||False|True|False|0|False||1|/CD" />
<add key="\\DS713\music\80's" value="0||False|False|False|-1|False||1|/80's" />
<add key="\\DS713\music\Arrow Classic Rock 50 2014" value="0||False|False|False|0|False||1|/Arrow Classic Rock 50 2014" />
<add key="\\DS713\music\Conferences" value="0||False|True|False|0|False||1|/Conferences" />
<add key="\\DS713\music\Ctrlaltlive muziek" value="0||False|True|False|0|False||1|/Ctrlaltlive muziek" />
<add key="\\DS713\music\Disco Top 100 Allertijden 2014" value="0||False|False|False|0|False||1|/Disco Top 100 Allertijden 2014" />
<add key="\\DS713\music\Diversen" value="0||False|True|False|0|False||1|/Diversen" />
<add key="\\DS713\music\Friso's Radiostation\1960's" value="0||False|False|False|0|False||1|/1960's" />
<add key="\\DS713\music\Friso's Radiostation\1970's" value="0||False|False|False|0|False||1|/1970's" />
<add key="\\DS713\music\Friso's Radiostation\1980's" value="0||False|True|False|0|False||1|/1980's" />
<add key="\\DS713\music\Friso's Radiostation\1990's" value="0||False|True|False|0|False||1|/1990's" />
<add key="\\DS713\music\Friso's Radiostation\2000's" value="0||False|True|False|0|False||1|/2000's" />
<add key="\\DS713\music\Friso's Radiostation\FEEST" value="0||False|True|False|0|False||1|/FEEST" />
<add key="\\DS713\music\Friso's Radiostation\Hits" value="0||False|False|False|0|False||1|/Hits" />
<add key="\\DS713\music\Friso's Radiostation\Kerst" value="0||False|False|False|0|False||1|/Kerst" />
<add key="\\DS713\music\Friso's Radiostation\Kink 1600" value="0||False|True|False|0|False||1|/Kink 1600" />
<add key="\\DS713\music\Friso's Radiostation\Maxi singles" value="0||False|False|False|0|False||1|/Maxi singles" />
<add key="\\DS713\music\Friso's Radiostation\Piraten" value="0||False|False|False|0|False||1|/Piraten" />
<add key="\\DS713\music\Friso's Radiostation\Rock diversen" value="0||False|False|False|0|False||1|/Rock diversen" />
<add key="\\DS713\music\Friso's Radiostation\Schlager" value="0||False|False|False|0|False||1|/Schlager" />
<add key="\\DS713\music\Friso's Radiostation\veronica top 880 2009" value="0||False|False|False|0|False||1|/veronica top 880 2009" />
<add key="\\DS713\music\Playlists\1980'snonstop.pfp" value="0||False|True|False|0|False||1|1980'snonstop" />
<add key="\\DS713\music\Playlists\1990'snonstop.pfp" value="0||False|True|False|0|False||1|1990'snonstop" />
<add key="\\DS713\music\Playlists\2000's nonstop.pfp" value="0||False|True|False|0|False||1|2000's nonstop" />
<add key="\\DS713\music\Q-Music 90''s Top 500 (2010)" value="0||False|False|False|0|False||1|/Q-Music 90''s Top 500 (2010)" />
<add key="\\DS713\music\Playlists\247 80's.pfp" value="0||False|True|False|0|False||1|247 80's" />
<add key="\\DS713\music\Playlists\247 Albums.pfp" value="0||False|True|False|0|False||1|247 Albums" />
<add key="\\DS713\music\Playlists\247 Albumtracks.pfp" value="0||False|True|False|0|False||1|247 Albumtracks" />
<add key="\\DS713\music\Playlists\247 Classic Rocktracks.pfp" value="0||False|True|False|0|False||1|247 Classic Rocktracks" />
<add key="\\DS713\music\Playlists\Zomer alle jaren.pfp" value="0||False|True|False|0|False||1|Zomer alle jaren" />
<add key="\\DS713\music\TOP 2000 2014" value="0||False|False|False|0|False||1|/TOP 2000 2014" />
<add key="\\DS713\music\Playlists\Extended Versions.pfp" value="0||False|True|False|0|False||1|Extended Versions" />
<add key="\\DS713\music\Playlists\247 Danskneiters.pfp" value="0||False|True|False|0|False||1|247 Danskneiters" />
<add key="\\DS713\music\Friso's Radiostation\Evergreen Top 1000 Dossier 2015 - Flac - 0001 - 1000" value="0||False|False|False|0|False||1|/Evergreen Top 1000 Dossier 2015 - Flac - 0001 - 1000" />
<add key="\\DS713\music\Playlists\247 Inkeilers.pfp" value="0||False|True|False|0|False||1|247 Inkeilers" />
<add key="\\DS713\music\Radio 10 Top 810 Jaren 80" value="0||False|False|False|0|False||1|/Radio 10 Top 810 Jaren 80" />
<add key="\\DS713\music\iTunes" value="0||False|False|False|0|False||1|/iTunes" />
<add key="\\DS713\music\I-Tunes singles pack Vol1-29" value="0||False|False|False|0|False||1|/I-Tunes singles pack Vol1-29" />
<add key="\\DS713\music\Jaarlijsten" value="0||False|True|False|0|False||1|/Jaarlijsten" />
<add key="\\DS713\music\Top 40 Dossier 1981 final" value="0||False|False|False|0|False||1|/Top 40 Dossier 1981 final" />
</MediaLibraries>
Then started the server again, and nothing is there. This media file has worked before.
What can the problem be?
Friso
<MediaLibraries>
</MediaLibraries>
Friso
This is really driving me nuts. Deleted every entry and created a new one. Added all the media libraries and playlists like this
<configuration>
<configSections>
<sectionGroup name="ProppFrexx">
<section name="MediaLibraries" type="System.Configuration.NameValueSectionHandler, System, Culture=neutral, Custom=null" />
</sectionGroup>
</configSections>
<ProppFrexx>
<MediaLibraries>
<add key="\\DS713\music\80's" value="100||False|False|False|-1|False||1|/80's" />
<add key="\\DS713\music\Arrow Classic Rock 50 2014" value="450||False|False|False|-1|False||1|/Arrow Classic Rock 50 2014" />
<add key="\\DS713\music\CD" value="0||False|True|False|-1|False||1|/CD" />
<add key="\\DS713\music\Ctrlaltlive muziek" value="80||False|True|False|-1|False||1|/Ctrlaltlive muziek" />
<add key="\\DS713\music\Disco Top 100 Allertijden 2014" value="75||False|True|False|-1|False||1|/Disco Top 100 Allertijden 2014" />
<add key="\\DS713\music\Friso's Radiostation\1960's" value="500||False|True|False|-1|False||1|/1960's" />
<add key="\\DS713\music\Friso's Radiostation\1970's" value="500||False|True|False|-1|False||1|/1970's" />
<add key="\\DS713\music\Friso's Radiostation\1980's" value="1000||False|False|False|-1|False||1|/1980's" />
<add key="\\DS713\music\Friso's Radiostation\1990's" value="1000||False|False|False|-1|False||1|/1990's" />
<add key="\\DS713\music\Friso's Radiostation\2000's" value="1000||False|False|False|-1|False||1|/2000's" />
<add key="\\DS713\music\Friso's Radiostation\Evergreen Top 1000 Dossier 2015 - Flac - 0001 - 1000" value="800||False|True|False|-1|False||1|/Evergreen Top 1000 Dossier 2015 - Flac - 0001 - 1000" />
<add key="\\DS713\music\Friso's Radiostation\Hits" value="30||False|True|False|-1|False||1|/Hits" />
<add key="\\DS713\music\Friso's Radiostation\Kerst" value="500||False|True|False|-1|False||1|/Kerst" />
<add key="\\DS713\music\Friso's Radiostation\Kink 1600" value="1000||False|True|False|-1|False||1|/Kink 1600" />
<add key="\\DS713\music\Friso's Radiostation\Maxi singles" value="200||False|True|False|-1|False||1|/Maxi singles" />
<add key="\\DS713\music\Friso's Radiostation\Piraten" value="0||False|False|False|-1|False||1|/Piraten" />
<add key="\\DS713\music\Friso's Radiostation\Rock diversen" value="0||False|False|False|-1|False||1|/Rock diversen" />
<add key="\\DS713\music\Friso's Radiostation\Schlager" value="0||False|False|False|-1|False||1|/Schlager" />
<add key="\\DS713\music\Friso's Radiostation\Tips" value="0||False|False|False|-1|False||1|/Tips" />
<add key="\\DS713\music\Friso's Radiostation\veronica top 880 2009" value="865||False|True|False|-1|False||1|/veronica top 880 2009" />
<add key="\\DS713\music\iTunes" value="0||False|False|False|-1|False||1|/iTunes" />
<add key="\\DS713\music\I-Tunes singles pack Vol1-29" value="250||False|True|False|-1|False||1|/I-Tunes singles pack Vol1-29" />
<add key="\\DS713\music\Jaarlijsten" value="0||False|True|False|-1|False||1|/Jaarlijsten" />
<add key="\\DS713\music\Q-Music 90''s Top 500 (2010)" value="480||False|True|False|-1|False||1|/Q-Music 90''s Top 500 (2010)" />
<add key="\\DS713\music\Radio 10 Top 810 Jaren 80" value="800||False|True|False|-1|False||1|/Radio 10 Top 810 Jaren 80" />
<add key="\\DS713\music\TOP 2000 2014" value="1995||False|True|False|-1|False||1|/TOP 2000 2014" />
<add key="\\DS713\music\Playlists\247 80's.pfp" value="0||False|True|False|-1|False||1|247 80's" />
<add key="\\DS713\music\Playlists\247 Albums.pfp" value="0||False|True|False|-1|False||1|247 Albums" />
<add key="\\DS713\music\Playlists\247 Albumtracks.pfp" value="0||False|True|False|-1|False||1|247 Albumtracks" />
<add key="\\DS713\music\Playlists\247 Classic Rocktracks.pfp" value="300||False|True|False|-1|False||1|247 Classic Rocktracks" />
<add key="\\DS713\music\Playlists\247 Danskneiters.pfp" value="100||False|True|False|-1|False||1|247 Danskneiters" />
<add key="\\DS713\music\Playlists\247 Inkeilers.pfp" value="130||False|True|False|-1|False||1|247 Inkeilers" />
<add key="\\DS713\music\Playlists\1980'snonstop.pfp" value="250||False|True|False|-1|False||1|1980'snonstop" />
<add key="\\DS713\music\Playlists\1990'snonstop.pfp" value="1800||False|True|False|-1|False||1|1990'snonstop" />
<add key="\\DS713\music\Playlists\2000's nonstop.pfp" value="1000||False|True|False|-1|False||1|2000's nonstop" />
<add key="\\DS713\music\Playlists\Zomer alle jaren.pfp" value="399||False|True|False|-1|False||1|Zomer alle jaren" />
</MediaLibraries>
</ProppFrexx>
</configuration>
<configuration>
<configSections>
</sectionGroup>
</configSections>
<ProppFrexx>
<MediaLibraries>
</MediaLibraries>
</ProppFrexx>
</configuration>
- This is what i got when restarting the media librarie server
- Screen Shot 04-17-16 at 09.21 PM.JPG (72.5 KiB) Viewed 15113 times
