visual indicator for sweepers
moogwill
Post by moogwill »
a visual indicator for sweepers in the playlist window... maybe a dedicated column or something...
concrete situation:
you generate the playlist to voice-track a session.
two tracks following each other seems perfect to put a VT.
when you open the VT window you realize a Sweeper is playing right before the ramp of the second track.
you have to close the VT window, open the segue editor, suppress the sweeper, reset the attenuate audio markers, and get back to the VT window to finally record your VT.
a visual indicator and a full suppress fonction(including attenuation markers) would be very useful.
Thanks.
Thomas.
Re: visual indicator for sweepers
There is already a 'Remove All Settings...' function in the playlist context menu - see the 'TAG and Meta Data' sub-menu, which allows you to remove all Track Insert Events as well as all Volume Points.
I am not sure about a visual indicator in the playlist, as there are already so many option to colorize a playlist entry...
But I might add a direct option to the VT dialog to immediately remove all volume-points as well as all event entries.
With this option you gain both in one shot and there would be no need to exit the VT, as you can immediately clear the sweeper and its volume points.
