Adv & News font
Adv & News font
Hi Bernd
Is there any change in column width in v4 ?
Re: Adv & News font
Yes, that will be increased a bit in the next version - guess this is due to Microsofts new default font (Segue UI instead of Tahoma).
Re: Adv & News font
Fixed in v4.0.1.8 !
Re: Adv & News font
Not fixed
Re: Adv & News font
Here it's not ok:
It's a new win10 installation. Nothing is installed except PF
Re: Adv & News font
Sorry for not being so detailed.
My screen resolution is 1360X768.
I run Adv& News Management
I edit a campaign. Click Assign button. Slot assignment screen shows up (my last screenshot).
The same is at my backup pc where resolution is 1280x1024.
I have not changed any DPI setting (size of text... 100%).
As I told you I clean installed win10 and PF.
Re: Adv & News font
Ahh, that helped, so we have been talking about a DIFFERENT dialog then ;-)
As said, from your screenshot I couldn't identify any dialog title...
Re: Adv & News font
In the v4.0.1.9-beta that screen has now also been sized accordingly.
Re: Adv & News font
That's strange, here it is okay...
Are you testing another dialog, using any certain DPI settings? If yes, a more precise description where something is not as you like it would be highly appreciated...
Re: Adv & News font
PLEASE READ my comments ABOVE !!! And be more precise! - a simple: no it doesn't work does NOT help me !!!
I assume, we are looking at different dialogs - may be?
What are your DPI settings? Screen Resolution etc.
What dialog ARE YOU using in your tests? Is that also the 'Dynamic Overlay Assignment' dialog?
If no, which one are you using?
From your screenshots I can NOT identify them...
