Script Library editor enhancements
I have two simple wishes for the script library editor.
The first one is to to set "Script Settings" Panel Expandable/Collapsible. It uses too much screen space when you want to work with many script line elements.
The second is to be able to clone a script line entry.
Re: Script Library editor enhancements
Not sure about the first one. - what screen size are you using?
On a screen resolution 1920x1080 there fit ~30 script-lines; on a screen resolution 1920x1200 there fit ~35 script-lines - isn't that enough?
Collapsing the 'Script-Settings' header would probably gain just another 5 or 6 lines. Not sure, if that's worth the effort.
However, as you are still using v3, note, that any enhancements are anyhow only included into v4.
Cloning a script-line can already be done today. Simply press CTRL+C on an existing line.
