.pfp Feature request
kbuyukcelen
Post by kbuyukcelen »
I've seen nice features in ProppFrexx Playlist file like adding placeholders, speechs, documents etc.
We are generating playlists for our live shows.
- 1 song
- speech
- 1 song, jingle, 1 song
- speech
- 2 songs
etc.
Sometimes we forget disabling autoplay function. It would be very wonderful if we had an option to "add disable autoplay" item to propfrexx playlisty files.
Thanks and have a nice holiday.
Kaya.
kbuyukcelen
Re: .pfp Feature request
Add on:
Found something in user manual.
If I pass <pf:options>67108864</pf:options> to the pfp file(as 67108864 is stop autoplay code) does it stop autoplay?
Thanks.
Edit: I got it. In playlist right click, track options and select stopautoplay.
Thanks Bernd., you've really thought every idea that a broadcaster needs.
Good to see that you found exactly the option I was about to explain :-)
Have a good jumpstart into 2016.
Bernd
kbuyukcelen
I just have an issue.
Are; Right click => track settings => options global?
For example;
I applied a track setting in a playlist. Does this option saved to pfmd file?
I need temporary option for this.
Thanks.
No that option is applied only within that playlist.
This unless you explicitly save it to a pfmd file or to the audio TAG.
kbuyukcelen
I use pfmd files not id3 tags.
But only in new playlist window. I add a track option and it is saves to the pfmd file.
Are there any ways to dismiss saving to pfmd file?
Edit: I disabled auto save metadata to pfmd file. I think it is fine now.
Of course, if you have enabled the Auto Save meta data to pfmd file option it does what it sounds like ;-)
kbuyukcelen
Ok, thanks Bernd.
Have a nice year :)
