Downmix of hook container
Farbo
Post by Farbo »
I am unable to downmix hook container in AAC format just in MP3 format.
Downmix error.png (11.35 KiB) Viewed 13523 times
Peter
Re: Downmix of hook container
It seems you have selected "Convert To..." instead of "Downmix To..."!
This has also nothing to do with MP3 or AAC.
"Convert To..." only works with regular audio files.
"Downmix To..." also work with embedded containers.
So make sure you select the correct option.
Farbo
Post by Farbo »
Bernd, I did select downmix. All other formats besides AAC+ work correctly.
Peter
Fixed in v3.0.11.5!
Ahh, yes, I see what the issue is for AACplus...I'll correct that in the next version!
Farbo
Post by Farbo »
Thank you. I will update later this evening.
Peter
