Powergold Import
djbony
Powergold Import
Post by djbony »
Hi Bern, if I importing playlist from Powergold, Promos are marked as jingle. In PFOA v3 it's working correctly. In category settings I have promos marked as promo... Where is mistake? Thanks. Peter
Re: Powergold Import
What event type are you using in your PowerGold import log?
I recall, that based on several others PowerGold uses experiance I did change the AUD mapping. This however is by design and not a bug.
Here is a list if event type mappings used (for PowerGold, Music1 and others):
MUS : Music
AUD : Jingle
COM : Commercial
ANN : Announcement
NEW : News
LOC : Local
ADV : Advertising
REP : Report
PRO : Promo
EFF : SoundEffect
SWP : Sweeper
DRP : DropIn
SID : StationID
SPO : Sports
LOG : Logo
LIN : Liner
INT : Intro
BED: Bed
HOT : Hot
MU2 : Music2
SHW : Show
OTH : Other
TRF : Traffic
US1 : User1
US2 : User2
US3 : User3
US4 : User4
MSC : Miscellaneous
WEA : Weather
djbony
Post by djbony »
I used AUD. I know, that you expand Powergold Import... Could you send me an all options for Powergold Import? Thanks. I try a new table in your post. Thank you
djbony
Post by djbony »
Works... ;) Thanx
What do you mean by an all option?
djbony
Post by djbony »
I mean all import options...
djbony
Post by djbony »
Thanks, but this is a Music1 Imports
But ALL imports use exactly the same options - just the format (import fields) is slightly different - but almost the same.
djbony
Post by djbony »
radio42 wrote:But ALL imports use exactly the same options - just the format (import fields) is slightly different - but almost the same.
Super. Thank you!
