FTE MaxEarly bug
ExIT_FM
FTE MaxEarly bug
Post by ExIT_FM »
If I set a FTE in the script edit window, and I set the MaxEarly value to ie. 90sec, it lost its value when it gets added to the playlist.
(PFOA Enterprise 4.0.0.22 x64)
Re: FTE MaxEarly bug
I'll take a look...
a new v4.0.0.25-beta is available - so "Check for Beta-Versions..." (located under the blue question mark icon menu at the very top right).
Many Greets,
Bernd
ExIT_FM
Post by ExIT_FM »
Thank you! I'll check it.
Regards,
David
