v4.0.0.24 - stable
v4.0.0.24 - stable
Version v4.0.0.24 is out!
What's New?
  • New Transition 'StartWithCueInOrEndWithRampOfNextTrack' added
  • Option to specify a Default Sweeper Transition added
  • Mixing settings enhanced by various ACPD-Options
  • New 'Speech Insert' options added
  • Program-Import SpotBreak as EmbeddedContainer bug-fix
  • Drop Sweeper option to loaded playlist entry bug-fix
  • Overlay EndsAt bug-fix when nothing is playing
  • New import filename option "SCRIPT:*" added
  • Other smaller bug-fixes
  • stable
The new 'StartWithCueInOrEndsWithRampOfNextTrack' transition, in opposite to its 'VO:' counterpart would always use CueIn if no Ramp position is set.
In addition you can now specify your (default) Sweeper Transition type in the general settings, mixing section.
These ACPD-Options (see the ‘Mixing per Media Type…’ dialog) allows you to specify various options per Media Entry Type. Namely:
ForceRecalc: The segue-points are recalculated even if they already exist.
ClearAllSeguePoints: The segue-points are removed before they are (re)calculated.
NoCalcCueIn: The CueIn position is not (re)calculated.
NoCalcFullLevel: The FullLevel position is not (re)calculated.
NoCalcNext: The Next position is not (re)calculated.
NoCalcFadeOut: The FadeOut position is not (re)calculated.
NoCalcCueOut: The CueOut position is not (re)calculated.</value>
Thus, these options allow you for example to not calculate certain cue-points for certain media entry types.
The playlist context menu or playlist ribbon 'Add' now contains a new menu item called 'Speech Insert'. Here you can directly add a few predefined silence audio tracks (from 30sec. up to 30 min.). They all have a few track options already set:
- StopAtEnd
- SuppressTitleUpdates
- SuppressGlobalLogging
- SuppressPlaylistLogging
- SuppressACPD
Thus you could now quickly add those track to your playlist. Those entries are ONLY intended for a moderated show to insert a speech indicator!
[*]New import filename option "SCRIPT:*" added
Note, the '*' has to follow the SCRIPT: value. E.g.
SCRIPT:*TopOfHour
The '*' will resolve the related script immediately at import time (as discussed).
If only 1 track is returned that single track will be used directly; else an embedded container is used.
The 'BaseFolder' import option now also scans any sub-folders for matching files.
