v3.0.11.5 - stable
v3.0.11.5 - stable
Version 3.0.11.5 is out!
What's New?
  • Memory usage optimization
  • New Mixing-Hook-MixTime parameter added
  • Hook-Length display bug-fix
  • Save current Skin selection bug-fix
  • Save current Playlist InfoPanel bug-fix
  • Advertising: new 'Estimated Total Playouts' report
  • Playlist 'Show next Top of the Hour Break' option added
  • Playlist 'Show next Overlay Entry' option added
  • Playlist 'Show next Program Entry' option added
  • Playlist Cover column sizing bug-fix
  • Playlist DownmixTo-AACplus bug-fix
  • Scheduler remote reload bug-fix
  • Overlay Resume FadeIn time option added
  • Various other optimizations
  • Other smaller bug-fixes
  • stable
Farbo
Re: v3.0.11.4 - stable
Post by Farbo »
Bernd, Playlist 'Show next Overlay Entry' option added pays only for overlay items played as playlist insert or for every overlay entry, even the ones played in overlay player?
Peter
Farbo
Post by Farbo »
Sorry, I already see it is working for all overlays.
Peter
j0han
Re: v3.0.11.5 - stable
Post by j0han »
After the update i cant start PF.
On, Creating Mixer. I get
WASAPI could not add output stream.
Mixer: OUT :ERROR N/A, Intern AUX (High Def. Audio Device) WASAPI 44100hz (->MON)
Error: BASS_ERROR_HANDLE
WASAPI could not be created.
Mixer: MON :ERROR N/A, Speaker (High Def. Audio Device) WASAPI 48000Hz
Error: BASS_ERROR_FORMAT
Internal Mixer: BASS_ERROR_FORMAT
The output stream could not be started.
ERROR: BASS_OK
PFLPlayer output 'PFL' could not be found.
PFLPlayer could not be created!
********** Error/Exception Information **********
Error Source: ProppFrexx ONAIR.Void a(ProppFrexx.ex, System.String, ProppFrexx.a9)
   at ProppFrexx.d4.a(ex A_0, String A_1, a9 A_2)
   at ProppFrexx.aw.a(String A_0, Int32 A_1, Boolean A_2)
   at ProppFrexx.aw.g()
   at ProppFrexx.cw.ag(Object A_0, EventArgs A_1)
   at System.EventHandler.Invoke(Object sender, EventArgs e)
   at System.Windows.Forms.Form.OnLoad(EventArgs e)
   at DevExpress.XtraEditors.XtraForm.OnLoad(EventArgs e)
   at System.Windows.Forms.Form.OnCreateControl()
   at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
   at System.Windows.Forms.Control.CreateControl()
   at System.Windows.Forms.Control.WmShowWindow(Message& m)
   at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
   at System.Windows.Forms.Form.WmShowWindow(Message& m)
********** End **********
Had to delete whole radio42 folder in roaming.
Now it works..
j0han
Post by j0han »
I tried to just delete the default.mixer file. but it didt work, probably missed some files then.
Sounds like a similar issue as reported here:
viewtopic.php?f=7&t=146
Unfortunately this is due to a bad soundcard 'driver' update process.
However, you wouldn't have to delete the 'whole' AppUserData folder, but only the "*.mixer" files!
