v4.0.0.17 - stable
v4.0.0.17 - stable
Version 4.0.0.17 is out!
What's New?
  • WaveFrom direct mouse cue-point editing added
  • Playlist search optimized (STRG+G)
  • New BreakForm view for embedded containers
  • MusicMaster import enhancement
  • BSI Simian meta data compatibility added
  • CD-Ripping bug-fixes
  • GPIO Client auto-reconnect optimized
  • Other smaller bug-fixes
  • stable
In case a track doesn't contain the following cue-point yet, you can now directly set them from any WaveForm display (e.g. the SegueEditor, PFL Player, VoiceTracking etc.) by simply dragging a 'corner marker' with your mouse:
- CueIn : LowerLeft corner marker
- FullLevel : UpperLeft corner marker
- CueOut : LowerRight corner marker
- FadeOut : UpperRight corner marker
Note, that if a track already contains the above cue-points, a related yellow marker is shown and you can move it by dragging it in the lower half of the WaveForm.
You can also simply hold down the SHIFT key when clicking into the WaveForm. At the beginning of the track it directly set’s the Cue-In.
At the end of the track it directly set’s the Cue-Out. When you keep on holding the SHIFT key and Click & Drag the mouse cursor the Full-Level resp. Fade-Out position will be set as well.
So far the content of certain playlist entries (like e.g. embedded containers) could only be seen from the Info (ALT+2) or TAG Editoe (ALT+3) dialog.
Now a simple click on the entry type icon (at the front of the playlist entry) opens up a new popup window to display its content, e.g. the embedded container or playlist track.
A new compatibility option for BSI Simian tracks as been added (see general settings, section MetaData/WaveForm - click on the 'Compatibility...' button and set the 'Read BSI Meta Data TAG (Simian)' option), which allows you to directly read its Intro and Segue mix points as well as various other meta data attributes.
In certain cases the GPIO Client application did not automatically reconnect in case of a connection failure (e.g. after a machine reboot). This should hopefully now been fixed and optimized.
