PF crash every time i close it!
henkelar
Post by henkelar »
Every time it comes to saving the mixer input after im using the program for a time it chrash two times.
Im trying to reach my history but cant find it.
// Henrik Larsen
Re: PF crash every time i close it!
Please submit a more detailed error report.
What exactly crashes? What version are you using.
There must be either some error being logged in a file called "Error.log" contained in the ProppFrexx AppUserData folder OR a message in the Windows Event Log.
Please submit this!
henkelar
Post by henkelar »
Hi!
I found this in Windows Event Log (Google Translate).
Log Name: Application
Source: Application Error
Date: 2015-09-21 23:34:55
Event ID: 1000
Task Category: (100)
Level: Error
Keywords: Classic
User: Missing
Computer: henke
Description:
The error occurred in the program by name: ProppFrexx ONAIR.exe, version 4.0.0.16, timestamp 0x55fa9b31
, Failure occurred in the module by name: bass_vst.dll, version 2.4.0.8, time stamp 0x555f2b95
Exception code: 0xc000041d
Felförskjutning: 0x0000000000005526
Process ID 0x5ec
Program start time: 0x01d0f4a04d5a8a4e
Path to application: C: \ Program Files (x86) \ radio42 \ ProppFrexx ONAIR \ 4.0 \ ProppFrexx ONAIR.exe
Path to the module: C: \ Program Files (x86) \ radio42 \ ProppFrexx ONAIR \ 4.0 \ bass_vst.dll
Report ID 8f83cf48-40a9-43f3-883c-7daa322824f2
Full name incorrectly packages:
Application ID relative to the erroneous packages:
The event XML data:
<Event xmlns = "http://schemas.microsoft.com/win/2004/08/events/event">
  <System>
    <Provider Name = "Application Error" />
    <Eventid Qualifiers = "0"> 1000 </ eventid>
    <Level> 2 </ level>
    <Task> 100 </ Task>
    <Keywords> 0x80000000000000 </ Keywords>
    <All Time System Time = "2015-09-21T21: 34: 55.000000000Z" />
    <EventRecordID> 2429 </ EventRecordID>
    <Channel> Application </ Channel>
    <Computer> Henke </ Computer>
    <Security />
  </ System>
  <Event Data>
    <Data> ProppFrexx ONAIR.exe </ data>
    <Data> 4.0.0.16 </ data>
    <Data> 55fa9b31 </ data>
    <Data> bass_vst.dll </ data>
    <Data> 2.4.0.8 </ data>
    <Data> 555f2b95 </ data>
    <Data> c000041d </ data>
    <Data> 0000000000005526 </ data>
    <Data> 5ec </ data>
    <Data> 01d0f4a04d5a8a4e </ data>
    <Data> C: \ Program Files (x86) \ radio42 \ ProppFrexx ONAIR \ 4.0 \ ProppFrexx ONAIR.exe </ data>
    <Data> C: \ Program Files (x86) \ radio42 \ ProppFrexx ONAIR \ 4.0 \ bass_vst.dll </ data>
    <Data> 8f83cf48-40a9-43f3-883c-7daa322824f2 </ data>
    <Data>
    </ Data>
    <Data>
Hope that is what you are seeking for :)
// Henrik
henkelar
Post by henkelar »
Loggnamn: Application
Källa: Application Error
Datum: 2015-09-21 23:34:48
Händelse-ID: 1000
Aktivitetskategori:(100)
Nivå: Fel
Nyckelord: Klassiskt
Användare: Saknas
Dator: henke
Beskrivning:
Felet uppstod i programmet med namn: ProppFrexx ONAIR.exe, version 4.0.0.16, tidsstämpel 0x55fa9b31
, felet uppstod i modulen med namn: bass_vst.dll, version 2.4.0.8, tidsstämpel 0x555f2b95
Undantagskod: 0xc0000005
Process-ID: 0x5ec
Programmets starttid: 0x01d0f4a04d5a8a4e
Sökväg till program: C:\Program Files (x86)\radio42\ProppFrexx ONAIR\4.0\ProppFrexx ONAIR.exe
Sökväg till modul: C:\Program Files (x86)\radio42\ProppFrexx ONAIR\4.0\bass_vst.dll
Rapport-ID: 1359005f-cacb-4cf0-b035-36600fcaa1a7
Fullständigt namn på felaktigt paket:
Program-ID relativt till felaktigt paket:
Händelsens XML-data:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="Application Error" />
<EventID Qualifiers="0">1000</EventID>
<Level>2</Level>
<Task>100</Task>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2015-09-21T21:34:48.000000000Z" />
<EventRecordID>2427</EventRecordID>
<Channel>Application</Channel>
<Computer>henke</Computer>
<Security />
</System>
<EventData>
<Data>ProppFrexx ONAIR.exe</Data>
<Data>4.0.0.16</Data>
<Data>55fa9b31</Data>
<Data>bass_vst.dll</Data>
<Data>2.4.0.8</Data>
<Data>555f2b95</Data>
<Data>c0000005</Data>
<Data>0000000000005526</Data>
<Data>5ec</Data>
<Data>01d0f4a04d5a8a4e</Data>
<Data>C:\Program Files (x86)\radio42\ProppFrexx ONAIR\4.0\ProppFrexx ONAIR.exe</Data>
<Data>C:\Program Files (x86)\radio42\ProppFrexx ONAIR\4.0\bass_vst.dll</Data>
<Data>1359005f-cacb-4cf0-b035-36600fcaa1a7</Data>
<Data>
</Data>
<Data>
</Data>
</EventData>
</Event>
henkelar
Post by henkelar »
Source: .NET Runtime
Date: 2015-09-21 23:34:48
Event ID: 1026
Task Category: None
Level: Error
Keywords: Classic
User: Missing
Computer: henke
Description:
Application: ProppFrexx ONAIR.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Details: System.AccessViolationException
Stack:
   at Un4seen.Bass.Bass.BASS_StreamFree (Int32)
   at Un4seen.BassAsio.BassAsioHandler.a (Boolean)
   at ProppFrexx.ea.br ()
   at ProppFrexx.dh.a (System.Object, System.Windows.Forms.FormClosingEventArgs)
   at System.Windows.Forms.Form.OnFormClosing (System.Windows.Forms.FormClosingEventArgs)
   at System.Windows.Forms.Form.WmClose (System.Windows.Forms.Message ByRef)
   at DevExpress.XtraEditors.XtraForm.WndProc (System.Windows.Forms.Message ByRef)
   at System.Windows.Forms.NativeWindow.Callback (IntPtr, Int32, IntPtr, IntPtr)
   at System.Windows.Forms.NativeWindow.DefWndProc (System.Windows.Forms.Message ByRef)
   at DevExpress.Utils.Taskbar.Core.FilterWindow.WndProc (System.Windows.Forms.Message ByRef)
   at System.Windows.Forms.UnsafeNativeMethods.DefFrameProc (IntPtr, IntPtr, Int32, IntPtr, IntPtr)
   at System.Windows.Forms.Form.DefWndProc (System.Windows.Forms.Message ByRef)
   at System.Windows.Forms.Control.WndProc (System.Windows.Forms.Message ByRef)
   at System.Windows.Forms.Form.WmSysCommand (System.Windows.Forms.Message ByRef)
   at System.Windows.Forms.UnsafeNativeMethods.DispatchMessageW (MSG ByRef)
   at System.Windows.Forms.Application+ComponentManager.System.Windows.Forms.UnsafeNativeMethods.IMsoComponentManager.FPushMessageLoop(IntPtr, Int32, Int32)
   at System.Windows.Forms.Application + ThreadContext.RunMessageLoopInner (Int32, System.Windows.Forms.ApplicationContext)
   at System.Windows.Forms.Application + ThreadContext.RunMessageLoop (Int32, System.Windows.Forms.ApplicationContext)
   at ProppFrexx.d3.a (System.String [])
The event XML data:
  <System>
    <Provider Name = ". NET Runtime" />
    <Eventid Qualifiers = "0"> 1026 </ eventid>
    <Level> 2 </ level>
    <Task> 0 </ Task>
    <All Time System Time = "2015-09-21T21: 34: 48.000000000Z" />
    <EventRecordID> 2426 </ EventRecordID>
    <Security />
  </ System>
  <Event Data>
    <Data> Application: ProppFrexx ONAIR.exe
Stack:
</ Data>
  </ Event Data>
</ Event>
henkelar
Post by henkelar »
Sorry, I dont know if you wanted it all here.
I have the latest version of PF.
Thanks for the info!
It actually looks like an error in a VST DSP library (rather than directly in ProppFrexx) !
Which VST are you using?
Please try, if you can reproduce the error, if you do NOT use that/any VST at all.
E.g. please remove the VST(s) from the mixer channel; restart ProppFrexx and see, if the error happens again?
henkelar
Post by henkelar »
I use StereoTools.
Ok, i will try, probably it is StereoTools that not works with the program sometimes. I have perfect sound now and everything, i can live with that is crashing sometimes, as long it's not affecting PF.
// Henrik
What exact version of StereoTool are you using ?
And can you confirm that without using StereoTool the problem disappears?
I can absolutely not reproduce it here.
StereoTools is just working good here.
But you wanted to send me your settings!
