Input channel recording
ExIT_FM
Post by ExIT_FM »
I found a problem with the input channel recording. If I set the encoder type to MP3, it works fine until I restart the program. After I restart the PFOA it's switch back to WAV format. Can you solve this issue? (I use PFOA 4.0.0.15)
Thank you.
David
Re: Input channel recording
Where have you switched the encoder type?
In the mixer channel or general settings?
The default recording format and type is selected by the general settings, section Encoding/Recording. Note, that the default encoder type is defined per encoding profile. So just change it in the general settings.
The 'Select Encoder' option in the REC context menu of the mixer channel is by design just a temp. change.
ExIT_FM
Post by ExIT_FM »
I've changed in the context menu. I'll try the other way in the general settings.
ExIT_FM
Post by ExIT_FM »
Thank you Bernd, it's working perfectly now :D
