Quick mix
djanji
Quick mix
Post by djanji »
is it possible to add button or maybe right klik on Play Next Use Fading for quick mix f.e. if you give the jingles for news (if you are live) in playlist and just go with the next button it's to slow on mixing. But for mixing music it's OK.
Regards
Jani
Re: Quick mix
I am not sure what you mean?!
Are you talking about the manual fading time?
Note, that you can already adjust the mixing per Media Type - see general settings, section 'Mixing/Fading' and click on the 'Mixing per Media Type...' button! E.g. define different manual mixing/fading times for Music and Jingles.
In addition note, that there is already a 'Play Next Use Fading' (F9) and a 'Play Next Track' (SHIFT+F9) button - that latter doesn't use fading at all.
djanji
Re: Quick mix
Post by djanji »
Thanks,
I'm always surprise what all can be done.
Regards
Jani
Re: Quick mix
So I assume, that was exactly what you where looking for?!
