v4.0.0.9 - stable
v4.0.0.9 - stable
Version 4.0.0.9 is out!
What's New?
  • Winamp detection on Windows10 bug-fix
  • Font sizes optimizes
  • RSS Feed reading optimized
  • Other smaller bug-fixes
  • stable
The main reason for building this version. In order to use the AAC+ encoder for streaming, you need to have Winamp installed on your system. However, on Windows 10, the Winamp installation detection got broken, which now has been fixed.
Some smaller font size optimizations for better readability under Win8.1 and Win10.
There is now also a new experimental ProppFrexx ONAIR command-line option available. You might specify "-SegoeUI" when starting ProppFrexx ONAIR in order to use the new (and larger) Windows 8.1/10 default font. Note, that this will lead in an increased size of all UI elements. If you like it, use it; else just omit this new command-line option ;-)
If a RSS Feeds is set, it will now always be refreshed. An optional setting might be used to show an alert window with each new feed item received.
