Program scheduler
friso
Program scheduler
Post by friso »
Bernd
I know in the past that there were som key combinations in the program scheduler to copy/paste blocks, en several other things.
I could not find this in the manual. Can you give me a link to those shortcuts?
Thanx
Re: Program scheduler
Once you marked/selected an existing scheduler entry, you can create a copy by holding down the CTRL key while dragging that existing entry.
friso
Post by friso »
Bernd
Ok thanx, but is it also possible when deleting some blocks, you can multi select them and delete just the selected ones?
Friso
friso
Post by friso »
Bernd
Thanx
It indeed are recuring items. But thanx again for the quick response
Friso ;)
Yes, you can hold the SHIFT key while clicking on the items to mark multiple entries.
Then press the DEL key to delete them.
However, if these are recurring entries, a confirmation dialog might come-up for each of them...
