Playlist Import with New Embedded Hook Container.
Frank1977
Post by Frank1977 »
question:
I have a scheduler program (Music 1) that make log files for every day that I import in ProppFrexx.
What I would be done!, Is that from the imported log files from Music 1.
Every hour a New Embedded Hook Container would be made from 3 tracks in that hour.
and be imported in that hour about 15 min past 7.
Maybe, with a script????
Is this be possible automaticly?
Frank
Re: Playlist Import with New Embedded Hook Container.
Currently not, as I guess Music1 doesn't support such a feature as far as I know. And if PF imports an external log it takes that as is and doesn't modify it afterwards.
Frank1977
Post by Frank1977 »
Thanks for the quick reply!
I know now this is not possible with Music 1, In the future is this possible
if I do it with Proppfrexx Media libary if I put all my music there and do the Scheduling?
Frank
Yes I can put it onto the whish list for a future release.
Frank1977
Post by Frank1977 »
That would be great!
Thanks!
Frank
