v3.0.15.13 - stable
v3.0.15.13 - stable
Version 3.0.15.13 is out!
What's New?
  • Full StereoTool v7.70 RDS integration
  • Import external scheduler log CSV bug-fix
  • TouchUI optimizations
  • Memory-Leak bug-fix
  • Other smaller bug-fixes
  • stable
Together with the new StereoTool v7.70 VST version you are now able to directly control your RDS settings (PS and Radio Text as well as TP/TA). A set of new control-commands are used to directly update the RDS settings within the StereoTool VST (see the User Manual for more info):
MIXER_IN/OUTPUT_STEREOTOOL_SETPSTEXT : Sets a mixer StereoTool-VSTs RDS PSTtext.
MIXER_IN/OUTPUT_STEREOTOOL_SETRADIOTEXT : Sets a mixer StereoTool-VSTs RDS Radio Text.
MIXER_IN/OUTPUT_STEREOTOOL_SETTPTA : Sets a mixer StereoTool-VSTs RDS TP and TA.
Memory-Leak bug-fix
A slight .Net bug was detected, which might in some cases lead to a memory-leak.
