Drag and drop
SiriusRadio
Drag and drop
Post by SiriusRadio »
Hi
It would be great if i could jingles and more from a cartwall straight into a playlist instead select and search in a library?
A simple and quick way to randomize playlists as hotkey code?
Will :D
Re: Drag and drop
You can:-)
As the left click might start playback you must use the right mouse button to drag&drop tracks from the cartwall.
SiriusRadio
Re: Drag and drop
Super, thxs.
And the hotkey for randomize?
Re: Drag and drop
There is no hot key to randomize a playlist. As this is not a frequent task. So you need to use the menu resp. the ribbon tab item.
SiriusRadio
Re: Drag and drop
radio42 wrote:There is no hot key to randomize a playlist. As this is not a frequent task. So you need to use the menu resp. the ribbon tab item.
It is a Wish List post :) :D :D
Re: Drag and drop
Do you may be want to play items from a loaded playlist in random order?
If yes, note, that you can toggle the playlist AutoPlay mode to 'Random' (default is of course 'Sequential') - see the ribbon bar for details.
Or use the PLS_CURRENT_AUTOPLAYRANDOM_ON command.
Or do you want to 'sort' the playlist items in random order?
