MOD Stream URL
Farbo
MOD Stream URL
Post by Farbo »
Bernd, how or where can I change MOD stream URL for playing next time? For thi first time I was able to set URL but next time I launched MOD stream I am not able to choose URL. I know it is possible through settings but could there be some more convenient way of changing URL for MOD stream?
Peter
Re: MOD Stream URL
The other way (than changing it within the settings) is using the related control-command.
See here: viewtopic.php?f=9&t=57&p=212&hilit=modstream#p212
Farbo
Re: MOD Stream URL
Post by Farbo »
I rather meant to change URL when MOD stream window appears. For example with right click?
Peter
Re: MOD Stream URL
Normaly the MODStream is rather static.
How often do you need to change that and what#s the background?
isn't changing that via the settings enough.
However, if you need multiple MODStreams, the above explained control-command might be used with a User-Command button...?!
Farbo
Re: MOD Stream URL
Post by Farbo »
OK, thank you. I do not need to change it often. It was just an idea which could be more user friendly.
Peter
Farbo
Re: MOD Stream URL
Post by Farbo »
Yes, that is fine. You know, people are often used to change anything as easy as possible. As I said, it was just a suggestion.
Peter
Re: MOD Stream URL
Oki,
but when there is no need to change it often, I guess changing it within the general settings dialog is sufficient.
