Out of memory exception (v3.0.15.10)
Hello Benrd.
I am trying to find why I get "Out of memory exception" with version 3.0.15.10
I have not changed anything to my PC, just updated to the latest PF version (and the latest MS updates).
This exception has happened two times resulting in dead air.
04/05/2015 03:58:28: Overlay-Scheduler-Start-Exception: 04/05/2015 03:58:28 [v3.0.15.10]:********** Error/Exception Information **********
Error Message: An exception was thrown by a TaskScheduler.
Error Type: System.Threading.Tasks.TaskSchedulerException
Error Source: mscorlib.Void ScheduleAndStart(Boolean)
Inner Exception: Exception of type 'System.OutOfMemoryException' was thrown.
   at System.Threading.Tasks.Task.ScheduleAndStart(Boolean needsProtection)
   at System.Threading.Tasks.Task.InternalStartNew(Task creatingTask, Delegate action, Object state, CancellationToken cancellationToken, TaskScheduler scheduler, TaskCreationOptions options, InternalTaskOptions internalOptions, StackCrawlMark& stackMark)
   at System.Threading.Tasks.TaskFactory.StartNew(Action action, TaskCreationOptions creationOptions)
   at ProppFrexx.Player.b.h(i A_0)
   at ProppFrexx.de.a(i A_0)
   at ProppFrexx.de.a(List`1 A_0)
   at ProppFrexx.de.ad.a()
Error Message: Exception of type 'System.OutOfMemoryException' was thrown.
Error Type: System.OutOfMemoryException
Error Source: mscorlib.Void StartInternal(System.Security.Principal.IPrincipal, System.Threading.StackCrawlMark ByRef)
   at System.Threading.Thread.StartInternal(IPrincipal principal, StackCrawlMark& stackMark)
   at System.Threading.Thread.Start(StackCrawlMark& stackMark)
   at System.Threading.Thread.Start(Object parameter)
   at System.Threading.Tasks.ThreadPoolTaskScheduler.QueueTask(Task task)
   at ProppFrexx.aa.a(Exception A_0, Boolean A_1)
   at System.Threading.Tasks.Task.InnerInvoke()
   at System.Threading.Tasks.Task.ExecutionContextCallback(Object obj)
   at System.Threading.Tasks.Task.System.Threading.IThreadPoolWorkItem.ExecuteWorkItem()
   at System.Threading._ThreadPoolWaitCallback.PerformWaitCallback()
********** End **********
Today when this happened, I started my backup pc and when PF started, it saw that it loaded two of the three DJ players. I mean that the waveform of first DJ player couldn't load. Of course PF could not start playing.
I then force closed it, restored from backup previous version (v3.0.15.9) and PF started playing normally.
I did the same to my onair pc (I restored from backup v3.0.15.9)
I am not posting this to the Bug Board because I don't know PF bug or my system's.
That's my memory use:
2015-05-04 task manager.png (124.75 KiB) Viewed 6920 times
Any help ?
Re: Out of memory exception (v3.0.15.10)
To download and install the .9 version manually use this link:
http://www.proppfrexx.radio42.com/downl ... e30159.zip
SiriusRadio
Post by SiriusRadio »
Bernd.
Several users i know experienced these problems as well.
It happend after the update. I even saw a blue screen. All settings are gone, same as soundcard settings.
Good luck fixing.
Will
As said then use the .9. Version. You can simply roll back by using the "Previous Version" folder.
It is however strange as the few users I contacted do not have any issues. So it might something specific may be related to a certain OS version?
SiriusRadio
Bernd,
we all have the same HP400 pcs. Exact clones with W7 and latest update.
Soundcard Audigy and 2 Behringer UCA 202 USB.
We'll try the .9 version.
Thxs
Hard to say from here. Maybe something with the update went wrong. .10 really only contained minor tweaks. So if the .9 is stable for you I'd suggest to stick with it.
I'll need to investigate, but that might take some time as I am currently on holiday ;-)
