Playlist Output Folder: (Playlist Output Folder)
Frank1977
Post by Frank1977 »
Question:
Evertime I import a logfile from a music 1 with the Program schedule log importer.
I always must select the "Playlist Output Folder" again, Is this not autmaticly saved once I selected this?
now is always: C:\Users\Frank\AppData\Roaming\radio42\ProppFrexx ONAIR\3.0\Music1 ProppFrexx
See below:
Program Schedule Log Importer.gif (119.58 KiB) Viewed 4805 times
How can I changed this so it is always the same folder?
Frank
Re: Playlist Output Folder: (Playlist Output Folder)
Within the ProppFrexx AppUserData folder you will find a file called “ProppFrexx ONAIR.importformats“.
This file contains the definition of the respective import formats, i.e. also for Music 1.
It is extensible and configurable and is saved in plain XML format.
For Music 1 please locate the section starting with the line:
<format name="Music1 ProppFrexx" ...
The attribute "name=" will denote the name of your import format.
Now look out for the group starting with:
<options>
and find an entry called:
<option name="ImportPlaylistOutputFolder" value="" />
This option specifies (as the name suggests) the default output folder name for playlists.
You can simply modify this option value and specify your folder of choice, e.g.:
<option name="ImportPlaylistOutputFolder" value="C:\My Playlists\Import" />
Then save the file.
Before doing any modification, I suggest to make a backup of the file (just in case you need to restore it later).
Frank1977
Post by Frank1977 »
Thanks for the reply and explain it too me,
I'm gonna change this to the right lines.
Frank
