3.15.x - Control commands not executing
Joche
Post by Joche »
From the streaming config > Control commands i have added MIXER_OUTPUT_REC_ON OUT to start recording of my broadcast automatic at connect. I also have a control command to start the autoplay. The autoplay works but the recording does not start. If i use the test-button in the dialog it works correctly.
Re: 3.15.x - Control commands not executing
That sounds strange. I just tested it here and it works just fine.
Can you please show me your exact configuration (at best with a screen shoot) of your command configuration.
Are really both commands showing up in the control-command builder dialog (in the above list)?
No news? So I assume it is already solved and was a user error?
Joche
Post by Joche »
Sorry for a late reply. It is not solved. I had to take a photo since i couldnt fix a screen shot from that screen :)
(I wiil now try to investigate why I have no sound at all in 3.15.04 beta...)
Nothing? So I assume it was just an issue of correctly using the commands.
Then please arrange a TeamViewer session for today and send me your login details. As here all is working fine. So may be your recording settings are not correct.
Joche
Post by Joche »
Right now my ProppFrexx won't work at all, so I will have to sort that out first. I'll get back to you as soon as possible.
Joche
Post by Joche »
I did nothing, except upgrading to 3.15.04. :) After that I dont have any sound. Everything seems to work fine, no error messages, but the players wont play and i have no sound from my mike. :)
Joche
Post by Joche »
Upgraded to 3.15.5 now and suddenly everything work including the recording... :)
Aha, so you messed up the setup, config or what did you changed to make it not working anymore?
