Transition mode does not set to "None"
I am modifying some fixed time elements but I can not change "Transition mode" to "None". (I had set some other value when I created the script).
Everytime I open the script I see that the previous saved "mode" is set, instead of "None" I last saved.
Re: Transition mode does not set to "None"
Oh yes, I see where the bug is. It will be fixed in the next version!
You might now try the new v3.0.15.2-beta version - which should fix your reported issue.
It is currently only available from the “Check for Beta-Version…” menu item; which is located under the blue question-mark icon at the very top right of the main window.
