3.0.15.0 - Att volume in VT Window
andrerotgans
Post by andrerotgans »
I discovered what might be a bug in the new (latest) 3.0.15.0 version
- Create a playlist
- voicetrack
- After voicetrack, try to use the "Att Volume" button. It's not working, it doesn't open the usual dialog box
- when you enter the new segue window, you can use the attenuate voicetrack button, and it works.
- After applying voicetrack attenuation & closing down the segue window, the att volume button (in the normal VT window) does work again.
- And, when you don't close the VT window but use the next playlist track or next placeholder buttons to go another segue and do a new voicetrack : the button still works.
So, it seems like the first time you enter a VT window the Att Volume button is not working, untill you use the attenuate voicetrack button in the segue window. I've tried it on two different machines, same behaviour.
Kind regards, André
Re: 3.0.15.0 - Att volume in VT Window
Yes you are right - thanks for spotting.
That will be corrected in the official version!
As a workaround until then, always use the 'Attenuate A+C' function from within the build-in Segue-Editor.
Note, that you can activate the build-in Segue-Editor by either clicking on the SEGUE button or by right-clicking on the VT WaveForm.
