Migrate to a new computer
This forum is unmoderated!
Joche
Post by Joche »
I am migrating my ProppFrexx over to a new computer.
The problem is that it won't restore the backup files on the new computer. I only get a simple message saying "Restore failed" and thats that.
I really dont wanna re-do all my setup with mixers, midi-commands and all... Pleeeease help! :)
Re: Migrate to a new computer
The backup and restore feature assumes, that you do it on the same computer using the exact same drives/volumes and paths.
Else it is not working!
But...the backup creates copies of the config and other folders in an uncompressed way.
As such you can still restore most files manually.
