v3.0.15.1
v3.0.15.1
A new version v3.0.15.1 is available.
What's New?
  • Segue-Editor enhanced to dynamically show either 2 or 3 tracks
  • Voice-Tracking now directly contains a 3-track Segue-Editor
  • New Trackboard Hot-Toggle buttons
  • Broken Media Libs can now be reloaded
  • New Restore Layout button in general settings
  • Playback History now contains all metadata columns
  • Check to validate premature overlay playback ending added
  • Other smaller bug-fixes
  • stable
Finally our new 3-track segue editor is available. The Segue-Editor dynamically displays either 2 or 3 tracks depending on the size (length) of the 2nd track. If the length of the 2nd track would fit almost within the segue window (using the current zoom level) then a 3rd track is displayed - else only 2 tracks are displayed.
Depending on your segue window width (in default zoom level mode) 3 tracks are displayed, if the 2nd track is around 45 sec. to 1:30 min. long. This is perfect so that classic voice overs or shorter jingle tracks are always displayed in a 3-track mode.
In addition various other enhancements have been made to the Segue-Editor, like 1-click (CTRL+B) track attenuation around the 2nd track; better scrolling and mouse wheel support, more easy volume envelop editing (see the marker panel when you drag the mouse in an empty region) etc.
The Voice Tracking dialog now also directly contains a build-in version of the segue-editor - so that you can perfectly align your recorded voice track right away!
You can automatically open it after the recording via a new general setting, see section 'Recording/Encoding'.
The trackboard now offers 5 hot toggle buttons at the top of its window to quickly load 5 different trackborads. The first is always the default (as of today). The other 4 buttons can be assigned to either a playlist file or a folder. This is great for quickly switching the trackboard content, especially in live broadcast situations.
An option was added to the Media and Cartwall Library Management dialog to re-try to reload so far 'broken' libs.
Just click on the 'Reload' button when you have selected broken media lib(s) in order to try to refresh it.
A new button in the general setting, section 'Look and Feel' allows you to reload the last saved layout (e.g. in case you messed up your window panels and want them to have restored immediately).
See the column chooser of the Playback History by right-clicking on any tree list column header.
In case you use dynamic content to play via the overlay scheduler (e.g. files which are just replaced while the overlay starts) there might be very rare scenarios, where the file might end before its actual length. In that case an additional check was added to detect those premature playback endings.
Have fun...
andrerotgans
Re: v3.0.15.0 - beta
Post by andrerotgans »
Gentlemen, let your downloads begin ;)
Thanks Bernd, gonna give it a testrun !
