Not able to see bars
SiriusRadio
Post by SiriusRadio »
Hi.
Not able to see the mixer etc anymore.
I checked in the view box but Propffrex doesn't show anything.
At first i was able t see online, now its locked.
Can someone help me?
Will
Re: Not able to see bars
Please delete the .layout file in the AppUserData folder.
SiriusRadio
radio42 wrote:Please delete the .layout file in the AppUserData folder.
Were does that show?
In what directory?
The ProppFrexx AppUaserData folder!
viewtopic.php?f=9&t=20
SiriusRadio
radio42 wrote:The ProppFrexx AppUaserData folder!
We fixed it.
Thxs
Will
Note, that if you just closed a window/docking panel, that you can re-open it from the 'Show' ribbon bar.
Else you might also reset the layout from the 'Look and Feel' section within the general settings (which requires a restart afterwards).
So I guess you just closed some panels/windows and didn't know how to re-open them - as such this is not a bug and I'll move this topic to the Q&A section...
