CSV Dump Of The Library & History Related Fields
inl_inc
Post by inl_inc »
I can't find a way to add playback history related fields to the library dump. FYI i'm currently using folder based libraries and All Fields CSV export option.
Is there was a way to add the following fields to the export (it would save me a bunch of time from having to build my own stats using playlists).
Last Played At
Play Counter
Thanks for all your hard work.
INL
Re: CSV Dump Of The Library & History Related Fields
A media library can be exported to CSV using the general settings, section 'Folders/Libraries' - see the "Export Media Libraries..." button.
The internal entry statistic (which contains the play counter etc.) can not be exported.
The entry statistic is however a simple xml file contained in your ProppFrexx AppUserData folder called "ProppFrexx ONAIR.entrystats".
You might use that ON YOUR OWN RISK! and e.g. convert that...
