Extended history disabled setting is not saved.
When I uncheck the Use Extended history Check box, this setting is not saved.
It's always enabled.
Re: Extended history disabled setting is not saved.
For the global history settings this is NOT correct! Here all settings are saved and restored correctly.
For the script related history settings this seems to be true and will be fixed in a future version.
Fixed in v3.0.14.31
