Maybe its better to test updates first...
XTended
After updating to the latest version I decided finally to look to another system for automatic broadcasting. Everytime it seems to be there are more troubles than before....
Red cross and I can't use the script library editor anymore, because there isn't a dropdown menu anymore to choose my music libraries.
- proppfrexx_shit.jpg (114.08 KiB) Viewed 6397 times
Re: Maybe its better to test updates first...
Version 3.0.14.29 is out!
I reverted back to the previous UI lib and all is okay again.
Sorry, that I did not discover that bug, but I typically can only test all code where changes have been made...
Emmm it's not !I reverted back to the previous UI lib and all is okay again.
Just now I updated to .29 and the following exception raised:
14/12/2014 20:50:37 [v3.0.14.29]:********** Error/Exception Information **********
Error Message: Could not load file or assembly 'DevExpress.RichEdit.v14.1.Core, Version=14.1.8.0, Culture=neutral, PublicKeyToken=b88d1754d700e49a' or one of its dependencies. The system cannot find the file specified.
Error Type: System.IO.FileNotFoundException
Error Source: ProppFrexx ONAIR.Void b()
at ProppFrexx.a8.b()
at ProppFrexx.a8..ctor()
at ProppFrexx.hz.a()
at ProppFrexx.hz..ctor()
at ProppFrexx.dd.cq()
at ProppFrexx.dd..ctor(g A_0)
********** End **********
I am sorry to tell you, but I am in the same situation.After updating to the latest version I decided finally to look to another system for automatic broadcasting.
If I don't find a software that needs so much of my attention I 'll give up radio completely.
By the way:
I had this problem too!there isn't a dropdown menu anymore to choose my music libraries.
The script lib issue seems to be a bug in the UI lib I am using.
Unfortunately there are lately a lot of issues related to them...and I am almost forced to always use the latest version of them.
I am sorry, but the last 10 major errors have all been related to that UI lib - but exchanging that isn't so easy...
Then please try to re-download the zip or unzip it manually from here:
http://www.proppfrexx.radio42.com/downl ... 301429.zip
The file you mentioned is definitely contained in the updated zip - I just tested it here and it was working.
So like always...Murphy...
I can understand your frustration! and mine is as big as yours, but, those things unfortunately do happen when you are depended on 3rd party software...
The UI lib is provided by one of the biggest .Net tool vendors, even Microsoft uses some of their components...but as you can see, that doesn't help.
Changing the UI lib vendor is not an option - so the only chance is, that also I will enter in some serious talks with them.
