Upcoming overlays duration
Is there any explanation why every time I click the Upcoming overlays ribbon it shows different results in duration ? My clicks had a 4-5 secs difference.
Look at "Time is" overlay:
Here is shows at 17:30 00:02 and 18:00 00:02
Here it shows at 17:30 00:02 and 18:00 00:00
Here it shows at 17:30 00:00 and at 18:00 00:02
Re: Upcoming overlays duration
Maybe random selection of multiple advert tracks?
That's what I tried to explain when you requested the feature - that it is for advert slots not always possible to determine the exact tracks, if the slots are either overbooked or a campaign might contain multiple tracks (which are randomly) picked or if there are dynamic fillers used or other elements are dynamic/random...
But why when I click test overlay everything shows as it should ?
Now I see what you mean. And yes, its a slight bug when calculating the duration, but only in case the list of upcoming overlays contained exactly the same script to be executed.
That will be corrected with the next version.
Fixed in v3.0.14.28
