Listeners count on status bar
The listeners count in status bar does not show the correct number of listeners.
For example if I have 15 listeners it shows: 0 ... 14 ... 0 ... 14.
I had told you about this bug here but you've probably missed it.
I am running now PFOA version v.27 (in my backup pc)
Re: Listeners count on status bar
Ah yes, if a streaming server entry can not get the listener count (e.g. the server is unavailable or the config is incorrect); it returns -1 as the listener count. That's why it might in those cases be too less. Nothing critical, it will be fixed in a future version...
Fixed in v3.0.14.28
I 've updated to .29 but still not fixed :
Yes, that was one of the other bugs which I hoped to get fixed with the new UI lib version.
As I unfortunately now have to wait for even another UI lib fix, it might take some more time to get fixed...nothing I can do about at this moment.
Luckily this is a very very uncritical issue!
