Overlay stuck and PFOA stuck
Bernd I just now updated first my backup pc.
An overlay has started playing but the Playing/Remain Timer is stuck at 00:00:00
And the worst is that when overlay ended whole PFOA stopped responding anymore.
I have let it stucked in case you want to check what is going on with teamviewer.
Check your PM
Re: Overlay stuck and PFOA stuck
Any news ?
Michiel Bouwmeester
Post by Michiel Bouwmeester »
Same problem for me here but on the main system, I have reverted back to an older version.
Should now be fixed in v3.0.14.25!
Yes, there will be a fix available later today!
It's not fixed.
Please send me both of your .calendar files (Overlay and Program).
I have let it run here for 2 days on 2 machines and it never got stuck - so it is a bit puzzling...
Sent
Are you sure that you really used the new .25?
I received your .calendar files are did run them here for 5 hours now, but nothing got stuck.
I was of course using my audio files, but all as close as to your config.
I also added a few ads for certain overlays and let some overlays run without any ads etc.
It is really strange; so we might need to do a TeamViewer session to see what is going on.
Also, if you have - send me your debug log when it got 'stuck'. ..
Yes I am using .25
I 'll be at the studio in 15 minutes. If you want to check I 'll send you TV details.
