Replay Gain Settings
AladnaFm
Post by AladnaFm »
We want to try the replaygain option to give the songs an equal volume.
What are the best settings for this?
Mode:
Default:
Max:
Use Replay Gain in ACPD:
Auto ReplayGain Calculation:
replay gain.jpg (141.09 KiB) Viewed 3751 times
Greetz Jesper
Re: Replay Gain Settings
There is no optimal for these options.
ReplayGain calculates a perceived loudness value and lowers the volume accordingly.
In order to do so a ReplayGain value must be available within an audio file TAG data. If not the Default will be used. As such I would recommend enabling to calc it automatically.
Also see here:
viewtopic.php?f=9&t=1212
