Listener count
Listener count
I just updated to that latest version of PFOA and noticed that my listener count no longer works.
I stream with Icecast 2 and have the option "Show Listeners" enabled but nothing shows up.
As far as i know that last update was just to fix this problem
Greets,
Dirk
Greets,
Dirk
- Listener count.JPG (19.29 KiB) Viewed 5519 times
Re: Listener count
Thanx for your fast answer !
Using "source" did the trick, i worked with "admin"
Thank you and have a geat day
Dirk
Dirk
Re: Listener count
yes, but what have you entered for the Admin username and password?
Note, that you must provide the 'correct' data there! E.g. 'admin' as the username and the related passwords.
Some servers also work with the username 'source' and its related passwords.
