Some mystery occured when starting encoder
Farbo
Post by Farbo »
WHen starting PF and automatically streaming server, sometimes it happens streaming server is not started, i.e. PF shows "some mystery occured when trying to start encoder". But I can not tell you when exactly does this happen.
Peter
Re: Some mystery occured when starting encoder
Are you getting any errors in the streaming server?
E.g. try to click on the streaming server icon (which shows the warning symbol) to display the last server error message.
Farbo
Post by Farbo »
Now it´s working fine. So next time I get the error, I will copy it and send you.
Peter
Sounds like a temporary internet issue, either on your side or with the streaming server itself.
